Hi guys, where can i find the engine serial number on a 2.0 TS . i bought a 1.8 156 that has a 2.0 engine added. i want to know a little of the history of the engine. any advice on how i could do that?
The engine number is difficult to spot also the "engraving " is not deep so i use wet and dry paper and paint thinners to help spot the numbers.At the front of the engine is the exhaust manifold. On the right hand side of the engine slightly lower than the manifold where the engine joins the gearbox is a lump in the casting protruding outwards that you look down on , this has the numbers stamped on it hope that helps.
Is this lump with the numbers in a vertical or horizontal direction and can you still see it with all the engine components joined on?
