Hello,
does anyone know what the engine presure is in LB for my 155 2.0 8V 1995.. meaning, what did it hav as new.
Nicholas
Discussion Starter · #2 ·
Do you mean what the oil pressure should be ???
Or what the torque (power) should be ???
Marlon
Hmmm its not oil, and its not torque power.
its what you measure by putting a machine on the where the spark plugs go, and measure the preasure of the engine...?????
N
Nicholas:
N
So it's compression, then. But dunno what the value should be.. More important, than the exact value (if > 6 or so) ,is that all the cylinders show the same.
The exact value is dependant on the instrument and calibration. Differences between cylinders is the thing that counts.
If your using a convential compression tester then you would expect a reading between 125 and 150 on the gauge on each cylinder
At least that what most modern engines run at if one is considerably lower than the others then i think you got a problem or if there all roughly the same then all should be well :rolleyes: :D
Discussion Starter · #6 ·
Hmm thanks.... reason why i ask is that a buddy of mine has a Mazda 323, with 200 eek!
N
