1 - 2 of 2 Posts
hi everyone,
i own an alfa romeo 164 V6 TB which recently had the water pump belt broken since it was touching the plastic part covering the tire every time i took a turn. i had that repaired at the official alfa romeo servis and i also had a piece of the plastic tire cover cut of to prevent friction between it and the new belt. however, the car still raises temperature when the engine is running but the car is standing. i had everything rechecked and nothing seems to be wrong. does anyone have any suggestions?
..is the radiator ok..? i had to change the radiators in both of my tsparks at around 100k miles...
i'm sure you've checked already, but the other obvious things to check are that the fan is cutting in and the thermostat is working i suppose..
1 - 2 of 2 Posts
