Hi guy's, going to have the oil changed on my Giulietta 1.4 tb multi air, can any one tell me the difference between the selenia k pure and selenia star appart from the price lol, both are recommended for the car but which should i use.
onder:
Depends on which year MA you have. I have a 2012 build. Up till 2013 the correct oil is 5W40 C3 full synthetic. That is a definite fact. Selenia K and Star PE are the same thing in different bottle and these are 5w40 C3. My AR first dealer service put the K in my MA. The bottle on K has multiair written on it. Later models needed 0w30 (something to do with fuel efficiency issues) but I think they changed back to the original oil spec soon after.Selenia K Pure energy meets the requirements for use in Mercedes and BMW engines, meeting their more strict anti-wear and anti-oxidation requirements. It is, however, NOT on the approved MB229.51 list.
Any oil on that list is qualified for use in the MA engine.
https://bevo.mercedes-benz.com/bevolisten/229.51_en.html
Selenia was a Fiat company many years ago.Selenia is a Fiat company and they are just trying to sell their own oil.
All the oils in the MB229.51list are Acea C3, and all have a noack % of 10 or less like demanded by Fiat spec 9.55535-S2.Depends on which year MA you have. I have a 2012 build. Up till 2013 the correct oil is 5W40 C3 full synthetic. That is a definite fact. Selenia K and Star PE are the same thing in different bottle and these are 5w40 C3. My AR first dealer service put the K in my MA. The bottle on K has multiair written on it. Later models needed 0w30 (something to do with fuel efficiency issues) but I think they changed back to the original oil spec soon after.
However, MA definitely requires the correct oil to be added because incorrect oil is blamed for MA failures. There are quite a few oils apart from Selenia K or STar that will be good. Motul XClean 8100 is a fine oil for example or you could use Liqui Moly that fits the specs without any issues. These are probably better quality than Selenia. Selenia is a Fiat company and they are just trying to sell their own oil. They don't even actually give any approvals for any other oil brands for their cars at all.
That is so NOT true. It's either 5W-40 for older models or 0W-30 for newer. 0W-40 and 5W-30 were never approved, which is written specifically in the owner's manual. And for MA viscosity must be strictly followed.Selenia K Pure energy meets the requirements for use in Mercedes and BMW engines, meeting their more strict anti-wear and anti-oxidation requirements. It is, however, NOT on the approved MB229.51 list.
that is utter ********..
40 weight is a range from 12.5 to 16.3 Cst at 100°C or the latter is 30% more viscous than the first at the same temperature. in the 30 weights the most viscous are 35% heavier than the thinnest.
0w or 5w only makes a difference at -30°C. above -25°C they're both the same (SAE) viscosity.
What IS important is the HTHS viscosity of minimum 3.5 cp and the Noack of 10% or less. HTHS viscosity is the viscosity under stress and is directly related to wear and fuel consumption.
FIAT 9.55535-S2 followes the minimum ACEA C3 spec, excluding the demand for a noack of 10% maximum. ACEA allowes 13%. MB229.51 allowes 10% maximum AND requires further testing in engines to determine wear, oxidation and sludging.
ACEA C3 is also a diesel AND Petrol spec, as is Fiat 9.55535-S2 (and 9.55535-S1 which is analogous to ACEA C2 with noack under 10%)
so what changed that newer Multiair engines can use 5w-30 and older can't? I know: the carbon footprint reduced in the NEDC...
1. It was -28C here in Poland 2 years ago.the only difference between a 0w-30 and 5w-30 is at the extreme low temperature that the 0w and 5w are tested at. -25° has never been recorded here in the last 150 years, and both are the same viscosity at that temperature at that temperature. so there's no practical difference for UK and western-europe users.
Seems to me Alfa/Fiat chose a grade from the selenia portfolio which is most likely to increase their revenue.
the MB2289.51 list are all low saps oils, but yes, I do prefer full saps even in my diesel engine.
2 years, andyou're out of warranty, which is when the first oil change is due
So as above is the - Castrol Engine Oil (Edge 5W-40 With Titanium FST Fully Synthetic 4Ltr) for my 2011 1.4MA Petrol OK? Have checked and it complies to - Fiat 9.55535.S2-28°C is still above the limit for 5w
I change mine every 18k myself, but I got the warranty required 36k oil change at the dealer. the first oil change was after 5 months. I put in Castrol edge fst turbo diesel 5w-40...
Yes this one should be ok, I almost bought this one, though decided to just go safe and take the Selenia.So as above is the - Castrol Engine Oil (Edge 5W-40 With Titanium FST Fully Synthetic 4Ltr) for my 2011 1.4MA Petrol OK? Have checked and it complies to - Fiat 9.55535.S2
It's ok, and I even used it in my diesel at the first oil change. But I wouldn't choose that oil right now for either diesel or petrol. It's way overpriced!So as above is the - Castrol Engine Oil (Edge 5W-40 With Titanium FST Fully Synthetic 4Ltr) for my 2011 1.4MA Petrol OK? Have checked and it complies to - Fiat 9.55535.S2
Cheers, So what Oil would you recommended? it was the oil 2 options on the parts site I was looking at, I do get 20% so was about £36 for 4 litresIt's ok, and I even used it in my diesel at the first oil change. But I wouldn't choose that oil right now for either diesel or petrol. It's way overpriced!
VW507.00 is a 5W30Get one with VW 507.00 ...
