1 - 10 of 10 Posts
Hello,
I swapped my 155 V6 for a 156 2.0 TS a couple of years ago, and now it's done 60k it's beginning to exhibit a few undesireable tendancies. One is a 'diesel' like noise on start-up, which I have heard is due to the 'variator'. What is this, and is it a difficult job to fix?
Thanks,
Brian King.
It is the variator, yes. Same thing was happening to my 2.0TS 147 at the same mileage. Was fixed as part of a 72k service.
The part is around £100 plus whatever your garage will charge per hour to fit it.
As for exactly what it does.......something about low-rev torque, I think, but someone elsewhere on this site will know more!!! Welcome.
Many thanks,
I'll trawl through the forum becasue I expect someone will have asked about this before.
Regards,
Brian King.
Brian, you'll feel better performance once it's fixed. When I got my 147 back from its last service, having had the variator replaced, it pulled so much better low down in the range - acceleration that had slowly disappeared over time was suddenly rediscovered. Great feeling.
Apparently the variator 'adjusts the timing of the inlet camshaft' but I read that somewhere, and don't know what it means :)
Thanks everyone,
Yes, it is lacking bottom-end pull. I've booked the car in with Jamie Porter to get it fixed.
Best regards,
Brian.
Welcome to AO. :)
Good luck with your Alfa. :D
1 - 10 of 10 Posts
