1 - 11 of 11 Posts
Just following on from another thread I started a few days ago I need to order all the engine mounts in the 2.4 JTD engine.
I cant seem to find confirmation that there are 4 mounts... One on the top left of the engine, then the gearbox mount, and then there are two others I think one at the front of the engine and another at the back.
Is this correct?
cheers Biffa, what are the symptoms of worn engine mounts? I would imagine excessive jumping of the engine or at least vibrations?
Ah actually one more thing, probably the most important for me - are the engine mounts for the 156 the same for all other 156's? I.e. will the engine mounts for the 1.6 156 fit the 2.4?
Cheers I'm doing the job in Poland so I found this:
PODUSZKA SKRZYNI LEWA ALFA ROMEO 146 147 156 JTD (2043880433) - Allegro.pl - Wi
Both the rear one as far as i know are the same as each other so i just need to order two of these
and then I found this one:
NOWA PODUSZKA SILNIKA ALFA ROMEO 156 2,4 jtd (2061431951) - Allegro.pl - Wi
So in your opinion I should just change the 3 yeah? and leave the box mount alone?
Both front ones look the same but are left and right, i would just change the top one and the rear engine mounts and leave the front ones.
Sorry to dig this thread but, i need to change the upper engine mount on my 147 JTD 2001 85kw.
So what is the procedure? I see 2 bolts, one on the chassis and one on the engine, if i remove it, do i have to put something to hold the engine, or it will be just fine?
Is there something else to remove and look after or just the 2 bolts?
Thanks.
1 - 11 of 11 Posts
