It is usually sensor related fault,you need to read fault codes with multiecuscan
Sent from my HUAWEI SCL-L01 using Tapatalk
Plug any generic code reader into the socket that is hidden behind the panel by your right knee. Couple of cross head screws to remove the panel, I think.
Autel-MaxiScan-MS309-OBD-II-Reader
The code reader above will give you the codes and reset the light (but not much else). Might even be cheaper to get a phone app and one of the blue tooth things. Sure they're less than a tenner.
Can't really make any judgement about fault without a code or description of symptoms. Does it drive ok? If you have a multimeter you could check the battery, as a weak battery can sometimes give spurious fault codes.
Chek at the back in the boot on your left hand side behind the panels is a computer chek if that plug is properly in its socet I had that problem
