2.0 ts P reg, 60,000 mls
Hello all
engine conyinully cuts out, originaly it was very occasionally but this last week it does it very often, camt go more than half a mile without it stalling, it does seem to be much worse after hitting a pot hole. -----> so poss just loose connection.
Any ways, people have suggeested the TDC sensor or the crank angle sensor, but I need to know where these are or what else to look for
Any help much apppreciated
Pete
Check your plug leads aren't loose. Sounds daft but when I first replaced mine, the car would cut out then restart like a bump start. Turned out the leads weren't sitting in the coils properly.
Marlon
After a bit of mauling and clinaning connectors up the world is good again, didnt see anything that looked like the cause but it seems to have sorted it.
Quite intrigued as to what it would have been, by the way power is back to what it should be, I hadnt realised what i had lost
Pete
