Any one know why this is happening.
The car is a 2.0 twinspark andhas been of the road for abput 2 months after headgasket failed. After getting the head skimmed and rebuilding it with new belts and tensioners etc it was running fine had it running on the drive for 1/2 hour with out any issues untill I fitted the air filter and maf. As soon as I plugged in the maf sensor it cut out, I removed and cleaned it but no different so I tried my spare one and it did the same.
Any help appreciated.
its difficult to believe both are bad.
have you checked the 5 wires in the connector?
maybe disconenct the battery for 45 mins & re-conenct the maf before re-connecting the battery
alternative, get the car diagnosed & clear the errors
I will have a check of the wires in the plug in the mourning and try what you said with the battery the battery has been of it for about a month.
ok, what fixed it?
disconnecting the battery?
