· Registered
While following ShiftyBloke's EGR Valve cleaning instructions I noticed something didn't quite match up regarding the removal of the engine cover.
I removed the 3 bolts and the cover came away immediately, I didn't have to pull apart a popper in the top right hand side.
Where I suspect the popper should be there is a bolt-like item appearing from the bottom of the underside of the cover (no bolt head though) which slots into a larger bolt-hole in the top of the engine. The bolt in the cover is a few mm's smaller than the bolt-hole in the engine as though there should be something that sits between them. Obviously it's not critical but it does mean the engine cover rattles a bit when the engine's running.
Is there a simple item that screws into the hole for the bolt to slot into?
Cheers,
Ecnarfi
· Premium Member
Usually it's a big bit of rubber in the cover and a ball headed bolt on the engine that it fits onto. Have a look around the engine to see if it's fallen off as you removed the cover.
