Sad times. Yesterday I took my GT to a well respected Alfa specialist (Peak Alfa) and this is the list of faults I was presented with.
1. Play in D/S upper front wishbone
2. Play in P/S lower front wishbone
3. Rear tyres worn & distorted
4. All wheels have slight buckles
5. Hand brake cables need replacing
6. Exhaust blowing around the turbo
7. Exhaust blowing from tailpipe
8. Major oil leak around rear of engine - possible rear crank oil seal
9. Clutch release bearing noisy
As you can see, this list of work is sure to threaten my ownership of an Alfa. The best estimate I can come up with for this work is around £2000, mainly owing to his advice that I should have both upper and lower wishbones on both sides replaced and the fact that he thinks that the clutch release bearing noise could actually be the DMF (this is after I told him I didn't think the car had ever had a new DMF).
So, I bought the car for £2500 in September, already spent approx £1000 on repairs and now I'm faced with this. Should I keep my 2005 GT JTD with 125k miles and save up from my minimum wage job to get the work done or should I sell up and go back to mediocrity and buy a ford or VW...
