Hi all.
New to the group and need help with my 2005 1.9JTD Alfa GT if you could please.
Today as I started out driving I pressed the windscreen button on my heating / AC panel to clear the screen. The tempature was reading 15°c on the dash and the heating / AC was set to 19°c. After about 5 mins of driving a strong burning electrical smell started to come through the vents closely followed by white smoke coming from the engine bay 😣
Car still drives fine so I'm assuming it's definitely a problem with the heating / ac?
I will probably get some time to investigate it tomorrow but does anyone happen to have any ideas what may of caused this before I start poking around?
Thanks in advance
Gg
Has your Diesel got the auxiliary heater?
Hi David
Thanks for the reply.
Trying not to sound dumb here but how would I know?
I've only had the car a few weeks and it's my first Alfa
Administrator
Alfa 159 1.9 JTDm Sportwagon
Does the heater fan still work at all speeds?
Thanks for the reply Paul.
I have literally just discovered what the problem is. It turned out to be the air con compressor / pump which leads onto my next question.
Any ideas on how much it's to get replaced or how hard it is to replace yourself?
It can be changed yourself but the gas should be recovered before changing and would need to be recharged afterwards.
