I am stuck trying to get the electrical connector off the EGR. I have removed a yellow slider from the connector but don't know if it now just needs brute force or some other trick to get it off. Help appreciated.
The yellow slider should just click out about 5-8mm and then the plug should just slide off.
May be worth sliding a fine flat bade screw driver in from the other end just in case the peg is stuck down.
Thanks . will try again in the morning.
Mine is the other way around, it does not want to stay on. Even with the yellow clip in it still needs a cable tie or it just falls off, go figure eh.
