Its not unknown for them to seize in the window "rubbers" if they haven't been used for a while (Sportwagons tend to be worse for this)....sometimes running a thin blade around the glass / guide joint, then "assisting" the window to move with a hand on each side of the glass whilst the switch is operated can get them moving. If you do get them moving, lubricate the guides with silicone spray....and operate them regularly.
But, you haven't pressed the isolator switch on the control panel, have you? ;)
