hi
i am pretty sure this is a main fuse which has blown as per title i am not getting power to the wipers indicators heating cigar lighter o even windows i have checked the fuses all good but no power in the main fuse on top of battery arew fine and according to the handbook there should be more at the suspension top on rhs however these i cannot find to check as not pesent the car is a 156 sportwagon on a 2000 any help would be much appreciated even a push in the right direction as i really dont fancy running a new wire to these components
hope someone can help
Jason
then my firend there is a fuse blown in the fuse panel.... pg 147 of owners manual
indicators: bottom row, most right [ 7.5a ] of the UPPER SET OF fuses
wipers: 2nd row, most rhs, 10a, main fuse panel
Did you find the main reason for this issue? I have the exact same problem right now. All fuses have been tested and are ok.
Battery voltage is 12.04V with engine off - is it ok, or could it be bad battery that's the reason?
