Banned
On Saturday, my passenger side widow decided to fail, whilst in the down position :rolleyes:
I could still hear the motor clicking when the switch was pressed.
Today finally managed to get into the door, and after disconecting the window from the mechanism, the motor worked fine, but after re assembling the window will go down, but not up. Would this be a sign of the motor failing & not having enough power to lift the window? If so has anyone got a second hand one they would like to part with for a reasonable sum of money?
Have you tried greasing everywhere including the window runners? I'm guessing it takes more effort to go up than down so it may help.
If not I've got a motor.
wrinx
That sounds like a weak motor as Wrinx says grease the runners but if the glass is sliding freely when not connected then the motor will dying frown
