i was about to fit a cd player in my car when 2 wires (red*black)which were with the speaker wires sparked together and this seems to have stoped my brake lights and front fog lights working. i have checked the fuses and they are fine. can anyone please tell me what i may have done and any possible cure.THANK YOU
Are you sure you`ve found all the fuses, as you may have overlooked some. Ive done this mistake before ( touching wires, and its a pain, Im an electrician so should know better :lol: )
Lee
Seems a bit odd that its stopped the fog lights and brake lights as they are on seperate fuses
Have you checked all the fuses properly ?????? :confused: they are in the main fusebox
Also check the services fuse just in case
In extreme cases, if a well oversize fuse has been fitted, the bulds may fail first, or if the wire strip on the bulb holder is corroded, it could burn just where it connects with the bulb...
Unlikely, but just a thought.
