My electric aerial didn't move, although a relay made a click sound.
I figured out how to remove it from the car (it has a ball-shaped nut screwed on to the aluminium outer aerial mast - pop it upward out of the grommet and then use suitable grips to unscrew, hopefully without too much damage).
Opening the casing, I removed the motor and tested it - worked, and the aerial mast and toothed 'rope' all seemed serviceable. The spacer/pressed-on clip had broken off the top of the clutch assembly - this turned out not to matter.
Once I removed the indexing switch, the problem became clear as you see in the picture below.
