hi my elec windows are giving me a few problems,done the soft reset a few times everthing ok for a few days, then pass window stops dropping and raising when you open door.this morning opened garage and passenger window was down,pressed switch and it raised as it should strange ??? Do I need to be concerned or is this part of being an ALFA owner only had car couple months
check battery. Funny things happen when battery power gets low.
I'd also disconnect the battery and do a full reset. There is a thread in the 'sticky' bit on what to do.
If that fails ...your window is broke!! ...but try the other bits first.
Take the door card off and behind it you will find the ecu for the window. Disconnect it and leave it for a few hours
