Hi whats the differance between Eibach springs? my 1998 156 2.0 SP2 I beleive has the blue/black Eibach springs fitted but I have been offered some of the Red ones which I believe are called sportline.
My question is will I benefit by fitting these?
The black springs are from Alfa and part of their Sport Pack, they are about 20mm lower than a standard 156.
Eibach then have 2 different springs for the 156, Pro and Sportline. Pro is -30mm lower and a bit harder than Sport Pack. Sportline are -45 to -50mm and presumably much harder.
The blue/black ones were made by Eibach to Alfa Romeo's specifications and gave a drop of 20mm. The red ones will be aftermarket Eibach springs, which usually give a 30mm drop and are usually much more progressive, ie soft initially but then really firming up once you get past the first bit of compression.
Ah, just read Pascs post, Sportline will give a serious reduction in ride-height compared to the blue/black ones. You would be wise to fit them with uprated dampers, maybe Koni Sport or the Bilstein ones that have a shortened damper rod.
I wouldnt fit Sportline springs, I would say they are too low...............might look good but I would imagine a nightmare to live with
If I got away with -60mm on a V6 I reckon -45mm is liveable on a TS. But you better not have piles :lol:
