Howdy, does anyone know if the two settings on the rear Eibach ARB are arranged so that the extra one is harder than 18mm or softer than 18mm?
well I believe that the hole that is not at the end of the bar is the harder of the 2 settings as you are decreasing the length of the arm, thus making it harder to twist.
Bit like a lever and fulcrum, the shorter the lever the more force needs to be used.
ya but is that the 18mm setting or is the one on the end the 18mm setting? :biglaugh:
