I have an offer to buy new Eibach Pro Kit for very very low price
but it is for 155 V6 and I have 155 Q4...
Should I put V6 springs on Q4?
Rear springs are with same catalogue number but front are not...
anyone had experience with springs?
thanks
Bojan
No idea, but I''ll ask some questions anyway :)
..but what are the weights of the two cars, and the front rear weight distribution percentages.
If they are very similar I couldn't see any problem..
Do you know the "spring ratings" of the two different front sets?
Cheers,
TB
thanks
Bojan
thanks
Bojan
i would just like to say if thay dont fit then i would be interested in the kit thanks jeff
@trailbraker
axle weights are +-10kg and track width is same as i know...
@alfajack
a friend of mine has Delta Grale and he had uprated springs which he additionaly !!!CUT!!! to make car even lower... result was that
his gearbox/diff malfunctioned because shafts were not in right angle
or something... so maybe that would be it...
@155 V6 - Jeff
sure if you want to pay postage from Serbia&Montenegro...
Good point - I should have mentioned to check the spring lengths as well as sprint rates.
The spring denotation is normally stamped on the springs like
"200-80" 200 being 20cm in length, and 80 being the spring rate (normally in N/mm).
sometimes you may be quoted lbs/inch
Heres a handy cross reference chart for spring types
http://www.hrsprings.com/site/motorsport/60mm.html#200
Cheers,
TB
