excuse my technical description :biglaugh: I meant the bilstein/koni are use Gas pressure technology as with the standard do not, so was thinking that they will quite firm and you will feel every bump!Gas thingy ?
I find the ride less crashy, but due to being less flexible you notice it over speed bumps.
My Mrs didn't notice lol
I've had lowered cars and hot hatches before and these springs still feel softer
Sent from my HTC One M9 using Tapatalk
I had this advisory in my MOT, nearside front lower Shock absorber has a slightly worn bush bush in lower suspension arm, do I replace the worn bush with new, or invest in some new shocks all roundAh right. No I found the opposite effect. So going over a small pothole previously would shake my bones, however now it's no where near as bad. The general ride is improved.
Handling much improved.
or replace all the bushes with powerflex, will that make the shocks like new, or will they be degraded generally over time i.e. my car is 2009. Sorry for all the questions, but want to get this right :thumbup:I had this advisory in my MOT, nearside front lower Shock absorber has a slightly worn bush bush in lower suspension arm, do I replace the worn bush with new, or invest in some new shocks all roundbefore I add the lowering springs?
I found these Koni STR.T Shock Absorber. The Koni STR.T Shock Absorbers are designed to be a perfect companion to a car’s original equipment, standard or sport package springs as well as performance lowering springs of up to 40 mm.
25-30mm drop wont affect camber to that extreme... Tbh if you're shreading tyres in 1000 miles, it's sounds like either your rolling a slammed out stancer, or you've got some serious toe issues, or something is rubbing...Ok after some reading, sounds like my FSD and Eibach is the way to go.
I remeber asking this somewhere before, i really dont want to be replacing tyres often.
How is anyone with lowered shocks getting on with inner edge wear. I had issue on my 166 and was sick of changing tyres every 1000miles.
