JS I agree with you... My estimation was based on 16v engine, which can (optimistically) produce close to 190 with 80mm3, (but not on "dutch" dyno
His engine is a bit newer with higher fuel pressure, also his turbo is less restrictive than the one you used, also he must be running with some very high AFR at the moment, since his injection is limited to 80mm3... All this helps for a bit more power, but it is definetely still less than 190 (and that is very opyimistic to begin with)...
Vic that TDI does not produce 240bhp with that injection quantity, or maybe it does if duration maps were properly massacred with tuning... But in that case you cant compare anything, since you dont know his realistic injection quantity...
As JS said you will have to raise injection up to at least 100mm to achieve 220bhp.
As you probably know user yan.ko injects well over 100mm3 and he says that his car should produce around 220... Now compare that to your figures
