Hi
Got the classic EGR powerloss problem today. Total loss of power and engine running uneven. Have fixed this before by cleaning the EGR valve and MAP sensor. Did the same today, the power was back to normal for a couple of hundred meters, than the power disappeared again. Limped back home, waited 10 minutes and tried again. Power back to normal, then disappeared at the exact same place as the first time!
Downloaded Multiecuscan and connected to engine. The error log showed: "P0402 - EGR Valve - Signal high. Exhaust gas recirculation excessive flow detected"
When going in to the engine parameters I see that the EGR valve opening is constantly on '3,998%' and EGR control is 'OFF'. When driving, the EGR control sometimes (2 times in 15 minutes) go to 'ON' in 1-2 seconds and opening % increasing, then back to 'OFF' and '3,998%'.
Any ideas? Faulty EGR? Have checked the cables for bad connection.
BR
Christoffer
BR
Christoffer
