Guys, I used to reset my ecu with fiat ecu. It is no longer visable. The fuse is fine and the led on the cable lights. I have tried vag con in end mode. still nothing, any ideas?
What do you mean reset?When you say not visible ,is it just to you on the laptop or do you have problems with the ecu running on the car as well?
Just not being recognised on the laptop. I have checked the settings (which have not changed). I have tried a different computer as well as VAGCOM in OBD II mode to no avail.
You need a modified KKL cable
I have the correct cable and was working the week before! The. Ext week it could not discover the ecu anymore. The settings were not altered, dip switches set correctly and the fuse for the socket is intact. It just stopped being visable!
Cable malfunction.....
