1 - 10 of 10 Posts
Answered your own question there. Yes the immobiliser is part of the ecu. Its an alfa. Nothing is that simple unfortunately. :)
the ecu has a broken pin
so if i get an ecu ill need the chip out of the key?
yep. and the transponder box i think.
The little blue box that can be found in the drivers side footwell. above the peddles.
speak to autolusso thay will have everything you need.
obviously you will need an ecu from the same model car. i.e 2.0ts for example.
1 - 10 of 10 Posts
