I am sorry but i am not able to find the post on ECU error code reading on 16V's. I only found the list of the codes and that the injector light flash thing is not working.
I hear that you need to stick a voltage meter somewhere or connect a diode to some wires. Anyone tried that already?
Hvala :)
But i still can't make it work. As it is said in the post this should work on post Alfa Code cars. Mine is a late 96' and has the Alfa Code. Do i need to stick a light somewhere in the ECU then. If this is so please also direct me to a diagram of the pins. Because i don't have any technical docs (only user manual).
