Hey,
Is it possible to replace the ECU in a 2.5 V6 with one from a 3.0 V6 or 3.2 V6? (I am lead to believe they are the same)
Although I am getting my 2.5 pulled out and a 3.0 put in it's place in around a month, should I just wait until then or will it be incompatible with 2.5 electronics?
A
You don't even need to change it, especially since there is NO 156 3.0 V6 from factory.
And no, 2.5/3.0 ECU is different than 3.2 ECU. 2.5 and 3.0 should be the same, but as I said, you do not need to change it, it creates more problems than it solves, like having to reprogram the keys and such.
I've done the same; the engine will run on the 2.5 ECU, not correctly but it will run - then get it remapped and all will be well :)
