It never rains but it pours. Just put the clutch back together with a new release bearing in the GT and I have ABS and VDC Failure warnings on the dash at switch on: my "ASR Off" light is also on as might be expected.
I have a single fault showing in both the engine and ABS ECUs and that is Brake Switch. I know the brake pedal switch is working - at least partially- because the brake lights work. So does this mean there is some other kind of pressure sensor/switch somewhere in the system I could have disturbed during the gearbox removal and replacement, it seems too coincidental that the fault started exactly after I changed the clutch to not be my fault but I certainly didn't go anywhere near the brake pedal.
