I am having some electrical niggles and want to check all of the earthing points for corrosion. I know there is one on the front head as well as one on the gearbo, but where are the rest?
What kind of electrical niggles? Any particular reason why you suspect a fault routing to 0V?
Personal opinion: I would suggest that even if you do find corrosion at such points, the corrosion is just as likely to be protecting a decent connection beneath. Besides, they are generally located at positions that are well protected from the elements.
If you haven't already, do the basics: continuity checks to the equipment in question, measure the V+ present. Let us know if you find anything interesting.
try cleaning up the batery terminals, pour BOILING water over them, after remocing the conenctors & over the connectors too.... then apply vaseline over the tops of them to seal them for future corrosion.
earth points:
* gearbox x 1
* on each valance, jsut under head lights x 2 [ ...13mm headed bolts ]
* ecu frame [ t25 headed bolt ]
* on the head near throttle body [ TS ] or front head [ V6 ] ...13mm headed nuts
also earth points in boot x 2, around lights + 2 more on 'A' pillars, knee height
