·I've got a 2010 Giulietta and was wondering if there is a software upgrade that dims the DRL on the side when you indicate a turn? Like Audis etc do?
I did mean if there's another function within 100 mm it compromises the visibility of the indicator. The A5 indicator is just above the drl.I may be misunderstanding what you have said but I don't understand why the closer the functions are together makes it less desirable? Did you mean more than 100mm apart?
