My GTV has developed a noise in the from the clutch/gearbox area and i cant work out what it is. I had a new GTA clutch,soild flywheel,new slave cylinder & new gearbox oil on wednesday and now has this noise
The noise is on acceleration in 4th 5th and 6th only and sounds like a raspy type noise that goes if i press the cutch in. Also upon changing up gears at around 5.5 6K revs, if you bring the clutch in quite fast it will knock through the pedal
Any ideas as i havent a clue
