Guys,
The drivers window on my 97 widey stutters all the way up and down - push the button...it moves a few mil's and the relay clicks and then stops - go through the process probably 20 times to get the window fully up or down....it also seems to stop in the same places every time....so....
Got another motor/winder mechanism at the weekend and fitted that....first few goes perfect one touch up all the way then one touch down...job done thinks I!
Then, today....I'm back to the 'stutters' not as often...it'll move probably 40 -50mm each time before stopping....only now the window has started to fall towards the front of the car by 1/2 inch or so on the upward movement....I can get hlod of it and move it back and forward...it feels as if it is unsupported at the front lower edge.
I've had the door card and liner off again and cannot see anything obvious.....any suggestions...could the second motor also be no good?
Have the runners come loose?
