1 - 11 of 11 Posts
The window motor in my drivers door is fading fast. It has become a real nuicance at toll bridges and car parks. Is the same type of electric motor used in all four doors and is it possible to interchange them. My car is 1997 2.0TS.
cheers
Discussion Starter · #2 ·
the motors are not interchangable but you might find that a fiat tipo(5dr)or a lancia dedra will fit.
My driver window hasn't worked for about a year - at toll bridges I have to open the door!
How much is a new electric motor?
Ralf S.
The price from the local Alfa dealer is 300 euro. They call it a regulator rather that a motor. How can it be this price.
JD - the motor and the regulator are different items - the motor is er, the motor, and the regulator is the geared / jointed / whatevered mechanism than converts the rotary movement of a motor into the up / down movement of a window.
However, I'm having drivers window problems too - but wondered if it was the 'one touch' relay getting worn? The window start to open, then slows, then clicks off, sometimes with repeated clicking of the relay until I press the window button again. I thought it might be burnt out contacts on the relay. Any more guesses?
Discussion Starter · #8 ·
rickward, it is exactly as you describe. I will take the door apart this weekend if it stays dry and examine all the parts. Jimybob thanks for the part info and price. Is the same motor/regulator used in the 146.
jd
Funny you should say about it being dry too - mine only plays up in damp weather... argh! Italian electrics!
Discussion Starter · #10 ·
removed the interior door panel last night. 30 minute job for amateur, me. interior panel is well constructed and can be pull off without fear of damage. A second metal panel which covered and held everthing together was then removed to reveal a singe cylindrical motor mounted horizontally with a plastic pipe towards the front to take the internal worm or toothed cable that pushes the window up and down. On the door lock side of the motor is a metal pipe that swings in an arc uop to the base of the window, attaces to the glass and then continues vertically to the base of the door to support updown movement. This is not the motor/regulator type design I expected to find having viewed those used in the 164. not sure there are any serviceable parts in here.
1 - 11 of 11 Posts
