Hello all.
Had the drivers side window broken in last week, took nothing but left me with a lot of hassle. Had it replaced but the guy who did it could not get all of the shattered glass out from the inside of the door. Been getting it out slowly via the three drain holes in the base with a small screwdriver, is there any quicker way of doing it...can't get anything small enough in there to hoover it out. Any ideas folks?
Pete
J
Remove the door card and get a drain hose from a washing machine, cut the rubber bit off the end and tape it to the end of your Hoover hose. You should be able to get into all the nooks and crannys then.
J
Hey Jim.
Do you mean the corrugated one?
Pete
Yeah, the grey corrugated type, doesn't have to be that though, just anything around that diameter. I use somthing similar at work for hoovering limescale out of boilers, works a treat.
