1 - 2 of 2 Posts
My driver's window opens and closes fine by the buttons, but the auto open and close (or one touch I think it's called) doesn't always work. When it does and senses I've opened the door it goes down too much and doesn't come back up enough and leaves a gap when I close the door.
What might the problem be? Would it be a simple fix or a whole unit replace?
Also with the boot it comes up on the dash my boot is constantly open when it's not. Easy fix or not?
Thanks in advance.
Welcome. Windows. one touch sends window up or down without constantly holding switch. Because doors are framless, window drops or raises when door is opened or closed. There needs to be a re-set performed if battery has been disconnected. Any electrical problems to do with the boot will be fractured wire in the bundle between tailgate and body in top nearside corner of boot opening. Try splicing a wire in? Good luck.
1 - 2 of 2 Posts
