1 - 12 of 12 Posts
Hi everyone,
Does someone can tell me if the CV joint of a 156 2.4jtd can be fitted on 156 GTA?
Is there any else compatibilty for these CV joint?
I'm talking about the CV joint on wheel side.
Hi everyone,
Nope, a jtd / v6 outer cv joint is different and won't fit. I'm not aware of any commonality with other models either.
Expensive aren't they?:(
I've often thought about replacing the hub flanges & wheel bearings for std 156 fittings, then using 156 2.5 V6 driveshafts. Its quite a bit of work initially but will make driveshaft replacement a lot cheaper in the future, you can pick up 2.5 V6 driveshafts for not a lot of money.
Ok so if i do understand weel i can take the driveshaft of a 2.5 v6 for my GTA.
But i don´t have to change my hub? Pud you talk about quit of work, could you explain this?
You can only use 156 2.5 V6 driveshafts if you also use 156 2.5 V6 hub flanges. This is the hub flange:
http://www.ebay.co.uk/itm/140824943345
To change the hub flange you will also need to change the front wheel bearings.
They are thinner yes, at a guess probably 5 or 6mm thinner on the flanged end. I don't know if the main shafts are thinner or not. I should probably weigh some and see if there is a difference.
1 - 12 of 12 Posts
