1 - 13 of 13 Posts
Hi
After a couple of years of mostly town driving ( my 2006 159 on 136,000) we went to the "get engine checked" dashboard warning message and thereafter into limp home mode.
Fault code P2002 - blocked DPF. You know the story....
Unplugging the MAF overrided (if thats a proper word) the rev limiter to get home and after 2 days of clearing the code every hour or so with a £35 quid draper code reader to temp disable the limp mode, I tonight report the following fix..................
Wynnns DPF cleaner added (£7.50 with me trade card at Hafords) to a half a tank of asdas finest diesel - but problem was that it wouldn't run on m/way for long enough to regen with the MAF sensor connected before dropping back into limp.
After x3 resets (code clearances) I then disconnected the MAF and sat at 4000 rpm 70/80 mph on M23 in 3rd gear for 20 mins and went from Brighton M23 to M25. MPG reading went up n down so i successfully provoked a regen,
Reconnected the MAF sensor plug at M25 and drove back home - and all is now well.
Obs DPF is on the way out but so far so good and I guess I will be in the market for a 2' masonry drill in not too distant future ?
Hope this post makes sense and helps someone in similar situation.
Do ask me any questions if you have them....
Best
matt - Brighton
Personally, I'd use Archoil AR6500 DPF/Cat cleaner rather than Wynns, but glad ya got it regen'd ok.:thumbup:
Thanks,
I will look that up,
Intend to use the wynns (or similar) on a regular basis as its likey the DPF is on its last legs.
If it does give up I will try the drilling to out "fix".
Best
Matt
Great post. I am struggling with this very same issue. I will try this tomorrow.
Did you end up drilling the dpf?
Sent from my SM-A505FN using Tapatalk
had the same problem with same code , dpf bank 1 ….. not able to re=gen...… dpf out, cut in half,,,,,, cleaned and re welded and put back in place, egr blanked , codes cleared and re-mapped ,,, all good under the hood ….
Alfa 159 2.0 JTDm Lusso 6sp.
....but no MOT ever again (a properly conducted one at least) and potential of a £1000 fine if you get caught at a VOSA spot check. New or properly cleaned DPF would be a far better option. The proper fluid by Wynns that you fill the DPF with (after removal) is only about £25 and makes them like new.
Get it professionally emptied from ashes (i.e. rinsed) instead of drilled.... will be better for all of us and value of your car. DPF are there for a reason, messing with around with it will only cascade into more trouble codes I’m afraid.
So I spent the morning driving for at least 25 minutes at 120 kph at 3700 to 4000 rpm. I had the maf disconnected. I did not really notice anything happening during this period. Used the Wynns dpf cleaner additive.
I then cleared the engine warning light and reconnected the maf. Car had ok acceleration and power bur stuttered a bit. Then after 10 minutes of motorway engine light came on again. So I cleared the light and disconnected the maf. Drove then without problems. Only thing that does not seem to work is the cruise control.
Does this mean the maf is faulty?
Would it even do a regen with maf disconnected? Not sure if no maf reading would upset the ECU and inhibit regens.
Have you got mes to check live data for maf feedback and DPF differential pressures?
Have you checked pipework from DPF to differential sensor is clear and free from splits etc?
Also is it worth chucking a differential pressure sensor on as I had problems with my 159 that turned out to be faulty sensor.
Finally I would have the DPF off and use some off the car cleaner in it overnight and then give a good wash out. I have recently done my BMW one but didn’t have DPF cleaner so blanked it one end and filled with full fat coke then pressure washed it before gently drying out on the hob for 5 minutes. Clogging level dropped right down.
I am not sure I have any dpf issues left now. With maf connected power is back but engine stutters on acceleration. With maf disconnected no stuttering but a bit less power.
How do I detect a regen?
Any point in replacing the maf?
When it is doing a regen fuel consumption will plummet and boost gauge drops rapidly when taking foot off. Mine always have a tell tale puff of smoke and a more boomy exhaust.
If you can access live data on MES you can check MAF readings and also see when last regen happened.
Read Only
A cored DPF will sail through a proper MOT (well below particulate spec) as long as the car has been thrashed soundly for 200 miles beforehand, and it has a decent remap.
No it won't...virtually impossible for the car so pass the "no visible smoke" part of the test even if the levels are low. Also as soon as he taps it and find it's hollow or sees and welds that are not factory (if you do it that way) it's an instant fail regardless of emissions levels. Not to mention the big fine if your get caught in the road with it these days. Not worth it for the small gains you get. Before the law changed I gutted the one on my Jeep...did not feel any different afterwards!
Several on here have even failed the new visible smoke test...even with the DPF in place if it's a bit old. Mines now up to 218 horses (2.0) with the DPF in place...so why bother.
1 - 13 of 13 Posts
