Door catching on rubber trim ! Best solution to resolve??
373 views 1 reply 2 participants last post by  richardw1992
#1 ·
Hi
Have a 939 Spider and literally just today the drivers door card has just taken to catching on the rubber surround seal when the door closes. When you open it you have to really give it a tug but this naturally causes the door card to come away from the door itself.
Have temporarily resolved this by removing the seal but can anyone advice as to adjusting the door ? Panel gaps all look fine.
The passenger side is the same but not quite as bad
Thanks in advance
#2 ·
The door card should be screwed in place at multiple points along the bottom. So I don't see how this can happen unless someone has removed the screws.
In which case it sounds like some of the clips are probably broken behind the card too, suggest you remove and refit with new clips and screws.
