1 - 2 of 2 Posts
I've noticed that the driver's side sill cover is being gouged by the bottom front corner of the door card (just ahead and below of the speaker) I can't tell if the sill cover isn't properly clipped down or the door card is the culprit?
How difficult is the sill cover to get off and clip back down properly??
Can the position of the door card be slightly adjusted?
I've got a good second hand sill cover but I don't want to fit it until I've sorted it out.
There is a row of plastic fasteners under the door rubber which are easy. Then some metal screws at the bottom of the cover which are probably siezed if the cover hasn't been off for a while. I had to cut mine carefully with an angle grinder. It's a good idea to remove cover periodically cos crud builds up and rusts the sills. The door card only bolts on in one place.
Thinking about it you probably mean the cover in the door way. This just pulls off.
1 - 2 of 2 Posts
