my 03 147 has the door ajar warning sign on at all times.. and it sounds a warning chime ~10 times in a row the moment i move the car after starting the engine (never again)
i checked the tailgate, both doors and the bonnet... all are closed
what's the easiest way to test it? i bought it this way
Possibly a problem with the switch in the driver's door switch. Sure it's not the seatbelt ? You should also notice it via the interior light if the doorswitch doesn't work.
Sometimes it helps to reset bodycomputer by disconnecting negative lead of battery for 15 minutes or so.
Re chimes, you can also switch those off (volume to zero) from the computer/dash settings
it's definitely the door ajar warning
incidentally, i noticed if all doors are closed, dome light is off..
if open the driver door, or the passenger door, the light comes on
by that logic, my issue is not the doors... but either the tailgate or the bonnet
