1 - 20 of 29 Posts
Daughter started sixth form - the Epson we've had for a few years is pretty unreliable by now.
So.....looking for the following features:
-colour
-wireless & usb
-print both sides
-printer tray (rather than standing paper in the back of the thing)
-reasonably cheap inks
that's about it
Any suggestions to help me through the minefield gratefully received. :rambo:
Epson XP820 for me. Had it a year and no issues. It's colour, wireless, usb, prints both sides, has a paper tray, and ink reasonably cheap :) Great for photos too...
After much uumming and arrring and wasting money on colour HP ink cartridges that
get blocked/go dry and budget ink cartidges that don't work.
I binned the portable HP inkjet printer I'd been using for years and decided to go the B/W laser printer route.
I still have a canon photocard printer and the big colour printer at work if I need colour.
(Same for a student, no?)
https://www.amazon.co.uk/Ricoh-213w-Wireless-Laser-Printer/dp/B01K7RY1NC/
When the cartidge runs out I plan to bin the printer and get another one.
I'll be going down the route of laser I suspect as I rarely print in colour so may stretch to colour laser if I do... Mind you, I've only ever bought HP (they were monster printers in the 80's/90's and early noughties... But then I've been "happy" enough paying higher prices for cartridges because I've not gone through many - my first was the HP 5L, my "current" is an old 5550C that the cartridges will have dried up in as it's not been used in over 10(?) years... I rarely print these days and use the library if I need something that desperately... or the parents/in-laws!
WOT TT4N said ^^^. Get a £50 Brother laser as the majority of stuff will be B&W and the per page cost is 10% of faffy, rubbish, unreliable ink cartridges. Get a cheap InkJet for the odd page that needs colour and you will be less concerned about the cost of cartridges as you will use fewer :thumbs:
As above, B&W laser, mines a Staples manager special "Samsung", served me well even after being in storage for several years.
Mrs. V does colour at work if required.
Small cheap Samsung laser black and white is my friend and companion, and I'd take it to a desert island.
My daughter has a an Epson matching your spec, Elvis, and when it's on form it produces fabulous colour prints. However, if you don't use all colours frequently, the pinholes in the heads clog up. On the other hand, if you use it too often, the pinholes in the heads clog up.
On most inkjet printer makes, the print head is in the cartridge so you get a clean new one every time you change a cartridge. This is obviously wasteful, so Epson have fixed heads which are theoretically not user serviceable. When ours blocked, Epson helpfully offered to sell us a new printer. In the spirit of the DiY thread, I managed to clean them using isopropyl alcohol injected from a syringe via model aircraft fuel hosing, wiping the heads from underneath with pieces of photo paper bearing blobs of alcohol.
What also happens is that eventually the surplus ink reservoir fills up. This turns out to be a sponge which can't be accessed without dismantling the printer. If you dismantle and reassemble, you need factory software to reset the head alignment...
I really like my Samsung laser printer though.
Laser all the way if she is going to be doing any volume. Colour lasers are more expensive than colour inkjets, but after the second cartridge change, you're probably winning. They are also more likely to still be working after the summer holidays. You need an inkjet for decent photo printing.
Double sided is overrated. Paper is cheap, cheaper and more reliable than paper handling systems in bottom of the range printers.
Avoid anything made by HP.
I've had a fair amount of success with Canon over the last few years.
Canon Pixma range here. Easy to use and reliable and cheap to buy initially. Ink quite expensive though. I dabbled with non Canon cartridges and they were rubbish and waste of money.
I've got a Samsung colour laser (CLP 365).
No idea how much it cost to be honest as I purchased it out here back when I couldn't do the exchange rate so well so was probably horribly excessive with it.
Had it 2+ years now and been pretty trouble free. I think I've changed the 4 colour laser cartridges once - and I think they were expensive too...... can't recall.
Anyway - we end up printing everything B+W anyway so would go with a B+W laser next time and wouldn't bother with a colour laser again.
Discussion Starter #14
-colour :thinking: she says yes
-wireless & usb
revised spec
Any true mingebag would discourage colour printing by default. Likewise wireless is too easy to fire off summat to print. Having to connect your device before printing focuses the mind on what has been typed to review it first, so less wasted prints :thumbs:
I've had a Dell C1760nw for 2 years now, it's a colour laser and I think it's really good. I got it because not doing such a lot of printing nowadays I was sick of cartridges drying up or running out just when when you need them.
It only cost £80ish (special offer price - but I've seen them again at similar prices since). Best of all the toner cartridges (should I ever need any) are available from all of the "compatible" suppliers so are really cheap. It's wireless and/or usb. Easy to set up and found by all devices in the household (windows, linux, android). Doesn't have mechanical duplex but all printers, so far as I know, will print on both sides of the paper - you just need to turn the paper over - if you tell the printer software that's what you want it will print alternate pages then stop and tell you when and how to reload the sheets and then do the other sides. I've done booklets and leaflets this way too.
The paper feed is underneath the printer and will hold 50 sheets, the output sits nicely on the top of the printer when it comes out (it doesn't fly round the room like some I've had). When not in use the paper tray folds flat and clicks shut against the front of the printer and it becomes a smooth black box, about the size of a bread bin. Mine lives pretty unobtrusively under my desk but I suppose it could go anywhere in the house where there's a power point.
I really haven't found anything I dislike about it - much nicer text than any inkjet I've had - and I think the photo quality is at least as good too. REALLY low cost, high quality and high speed printing.
That's a good point about compatible cartridges on lasers.
It's just toner. There's not special ink formula or proprietary
jet technology so compatibles are more likely to work well.
Canon pixma MX720 in use here.
Reliable, affordable great quality, wifi, ethernet, duplex and two trays plus a very good scanner to boot.
AB Cartridges round the corner do very good compatible cartridges by post and they will replace if there are any issues.
Win - Win
Discussion Starter #20
Thanks for the advice all. I went in a different direction based on the information provided and bought a
Brother HL3140CW Colour Laser Printer and a spare set of compatible toners for £136 delivered. Lots of good reviews.
It's wireless, but apparently (if you don't read the 'structions) it can be a bit fiddly to set-up......so I just might not.
Fingers crossed. And thanks to everyone who provided advice. :tum:
(I don't think it's an actual laser - it's LED tech that fixes the image......:ponder:)
1 - 20 of 29 Posts
