1 - 2 of 2 Posts
So Following a few other issue i decided to clean my MAP sensor (2.0 jtdm 170)
This turned out to be a good move as it was completely blocked with crap. BUT, while carefully removing the senor (apparently not carefully enough) I snapped the clip on the back/bottom of the sensor that holds it in place along with the bolt.
Is this going to be problem eg. boost leak. If yes is it a new manifold?
They're usually a tight fit, can you fashion some tie wraps to hold it in place?
1 - 2 of 2 Posts
