Looking for some help.
2011 Mito Cloverleaf 170
Over the past few weeks DNA mode does not work at all. Cannot change to Dynamic or All Weather. It's as if the switch is dead.
However whenever the cars start/stop actually works (very rarely) the DNA switch works when the engine is off - can change to D and A, however whenever the engine starts again it just goes back to Normal and cannot change again. Not sure if this can help narrow down the problem.
I have an OBD scanner as well as the yellow adapter and AlfaOBD to check for codes.
I have done a scan on various different ECUS and this is what has come back.
SUSPENSION
C1037 - Front right valve, open circuit, error present.
BODY COMPUTER
B1067 - Dynamic control selector on CAN, error present.
B1074 - PROXI Configuration control, configuration failed, error present
B1047 - LIN Serial line, error intermittent
RADIO
U0140 - No communication with body computer, no signal / missing message
I do know that some of these faults existed before anyway as I've upgraded the radio from the original CD player to the newer touchscreen uconnect model which unfortunately meant a flashing odometer.
Anyway hoping that someone has experienced this before and maybe know the first things to check for.
Thanks!
SUSPENSION
BODY COMPUTER
RADIO
Thanks!
