Could have posted this in the Rant lounge :confused:
The spider had a dodgy headlight
But the picture says it all
Both the headlights are the same brightness now :eek:
Administrator
I wanted to remove the heater fan in my Coupe because it was a bit squeaky, but on trying to do so found that the electrical connection to it has welded itself together.
I decided discretion was the better part of valour, and left it in situ, since it still works!
Besides, the act of half removing and then replacing seems to have done some good - it only squeaks when you go around left hand bends now :confused:
Not good :eek: but at least it's sorted now eh ?? :)
I'm certainly pleased it turned out to be something simple and easily accessible :)
This is the third dodgy connector I've had on the Spider...
No 1 Killed the speedo... (a well hidden connector :mad: )
No 2 An indicator..... The multimeter showed volts ... but high resistance
No 3 This one.. :rolleyes:
I'm tempted to pull all the connectors and clean them :eek:
But I'm with Bazza...... if it aint broke ......
