Help! I'm in the middle of dismantling my passenger door, and the guides on here are very helpful up to where they say "disconnect the bowden cable".
How?? :confused:
It clips into the inside of the door handle in a way that seems to either need a special tool to remove, or else a lot of brute force ... am I missing something here?
there is a plastic collar that rotates on the cable and clips the cable holding the "L" piece of cable into the lock mechanism.................... all you need to do is swivel this collar out the way and then the "L" piece will be able to be removed
Thanks for the info - that's the white-ish L-shaped plastic piece that clips over the L-shaped bend?
