1 - 13 of 13 Posts
Gonna fit braided hoses and upgrade the front discs and pads to my V6 GTV :thumbs:
Can anyone recommend any, not for track but just fast road :confused:
Also will the calipers accomodate a bigger disc & can you use DOT5 fluid? :(
Don't use DOT5 brake fluid.
A good DOT4 or a DOT5.1 will be fine.
I don't think the calipers will accommodate bigger discs.
Use either Ferodo DS Performance or DS2500 pads with Castrol Response Super Dot 4 fluid.
I've got the ATE Blue brake fluid in mine now.
Made it very easy to see when bleeding.
They also do an identical spec Gold colour version, so you can alternate.
I can recommend Tarox sport japan discs & pads.Had then on my car a year now and am very pleased with them.Look good too:)
Thanks for the advice fellas :thumbs: Just gotta pick some discs and pads now :confused: May go to Demon Tweeks in Wrexham next week for a trolley dash :lol:
I think you'll be able to find the parts you require at a much better price if you shop around the net.
I've got them on mine now, the Ferodo DS2500s on stock discs is a better combination with some good fluid.
Red Dot brakes are very similar to Tarox so I'm led to believe.
If you can get PF pads, go for them:wow:
Simon, you can buy your discs from Red Dot with 40% discount if you are a club member.
Discussion Starter · #13 ·
Thanks for all your advice fella's :thumbs:
After much thought I have a plan and a shopping list :)
Stock front discs
Ferodo DS Performance Pads
Goodridge SS Braided hoses
ATE Super Blue Brake Fluid
I think that will do the trick :D
1 - 13 of 13 Posts
