1 - 2 of 2 Posts
Hello
Drove my GTV this morning, when I pulled up I had to park up and noticed that it was a bit of a shunt getting from forward gears into reverse.
It sounded a bit like the gearbox hadn't stopped spinning completely when I was trying to get it into reverse.
So after a bit of a noise (I assume when the cogs were stopping) it went in.
Took it to specialist who said:
Not too sure if it has rear syncromesh, therefore if you haven't given the cogs a chance to stop it will crunch in. With synchromesh it probably wouldn't do it.
Also could be clutch thinning and not completely dis-engaging.
What do you think?
Could it be normal for this car - apparently it is something that they have frequently seen and have advised to use the 2 second rule. ie depress clutch, count to 2, then engage the reverse gear to give it a chance to let the cogs stop.
I would really value your advice on this.
And before you ask, I have posted this in the GTV lounge aswell to widen the 'arc' of opinion.
Thank you
HI could be the clutch drag but if it goe,s in after the 2-3 second count it should be ok there are three cogs trying to line up in side the gearbox mabe nothing to worry about all my 145,s and155,s with simiilar gearboxes all sometimes suffer from this, a lot of custormers sometimes complain about this from time to time!
1 - 2 of 2 Posts
