1 - 13 of 13 Posts
Just out of intrest and because i have the 2.0 TS camlocks butt now i have a JTS.
Is there a difference in the camlock tools for a 2.0TS and a 2.0 JTS.
They are a different specification to the 2.0 TS cam's so that is qhy they require slightly different cam blocks.
I am curious to know the real difference between the 2.0 Twin Spark and 2.0 JTS cam lock tools. Can someone post a picture with both together ? I know a few mechanics who use TS locks on JTS engines.
Alfa JTS P/N 1870859000.
Alfa TS P/N 1825041000.
I know the part numbers are different but I want physical proof.
Valve lift is circa ~1mm higher on both Jts cams, if compared with CF2/CF3 1.8/2.0 TS. duration is also higher.
Even if they were the same cams, I'm sure it would need a different timing setup, due to DI.
Enviado desde mi MI 8 mediante Tapatalk
To me the one on right is different shape on right hand side of it. Hard to tell going by a grainy picture but they definitely look slightly different
If you download to your computer and compare they are the same. I would like to see the originals side by side.
Only way to tell is to get hold of both and compare them.
My thinking is there must be some difference as Alfa wouldn’t waste the money getting different locks machined if the cam profiles etc were the same between ts and jts. There would be no need,likewise dealers wouldn’t have both sets if they didn’t need to.
Administrator
Alfa 159 1.9 JTDm Sportwagon
Another site shows two different cams lock sets, as said no need if they were not required.
I ordered the original alfa JTS Cam Locks and we will see... I will keep all posted.
1 - 13 of 13 Posts
